LT80 Reed cage and black plastic spacer
Old Mar 10, 2009 | 03:50 PM
Bowls's Avatar
Default LT80 Reed cage and black plastic spacer
Would matching the black plastic spacer to the carb intake help in top end revs. I've already cleaned off the casting flashing on the leading edge just before the reeds. Not much, but every bit helps. Looking at the reed cage it tapers down quite a bit. Would it help to use a Dremel to open it up while I'm replacing the reeds? Ie make the squares taller to allow more airflow? The LT80 is only used in the sand, I've removed 2 rollers on the front, nothing else for now until the motor blows.
Photo links below:
After dremel
Text border="0" alt="Carb before dremel"&gt;&lt;/a&gt;">http://i729.photobucket.com/al...yahBoxer/CIMG0128.jpg"</a>
Text
File Type: jpg
Old Mar 12, 2009 | 08:05 AM
LT80's Avatar
LT80 Expert
You can make it a lil taller. Flow the right and left side too. You can't hurt it.
Leave the black thing (insulator) alone. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 12, 2009 | 11:01 AM
onebigzj's Avatar
I would cut the rear shoes. that will get u reving better and faster. and cost nothing. would work great in the sand!!!
Old Mar 13, 2009 | 11:18 AM
Bowls's Avatar
Thanks for taking the time to answer my questions.
Old May 19, 2010 | 11:07 PM
SNiXrOx's Avatar
Question Help with reed cage please!
I am trying to get the reed cage off my lt80 so that i can install the power reeds. but it seems the cage screws are way over tightened. any suggestions to help me get the screws lose and out?
Old May 20, 2010 | 08:04 AM
LT80's Avatar
LT80 Expert
I use a impact driver. You know, the thing you hit with a hammer.
They can be tough.
Old May 28, 2010 | 10:13 PM
stuartshomepc's Avatar
They can be tough.
I could not get the ones on my sons LT80 out by hand with a normal screwdriver either. I had to put a Phillips bit on some long socket wrench extensions to position the impact driver out in front of the engine skid plate. Using my hand impact driver (the one you hit with a hammer) with two good hits the screws popped loose. It was awkward but it worked!
Old Jun 4, 2010 | 04:15 AM
SNiXrOx's Avatar
ya it was some work. but finally got it off and got the new reeds installed and was way worth it thanks
Old Jun 4, 2010 | 06:56 AM
DAMONSQUAD's Avatar
did it make a noticeable difference? i might have to try it
Old Jun 4, 2010 | 09:55 AM
I took out the worn steel reeds and put in a set of Boysen Power Reeds. They were $19 at the local dirt bike shop. They seem to make it a bit more peppy at the low end, and it idles smoother now that they are sealing better.
