1998 450ES digital display problems
Old Mar 3, 2001 | 12:34 AM
JRDNORTAX's Avatar
I have a 1998 Honda 450ES. It has a digital display for the odometer, clock,
hourmeter etc. When you first turn the ignition on it displays all 8's, as
it is supposed to. After a few seconds it switches over to numbers. So far
so good, but........ the leading characters on the odometer remain as 8's,
though I know the mileage is not that high( I know there are less than 2000
miles on it). Also, the hourmeter reads all 9's and doesn't change. The
clock function seems to work fine and the odometer/tripmeter keeps advancing but just has the 8's in front of the actual mileage.. Any guesses as to the problem?????? Loose
connection? Where? What else?
Talked to the local dealers, but they seem to want to replace the whole unit,
or don't know (or won't tell me) whats wrong.
John Dykstra
JRDNORTAX@aol.com
Old Mar 4, 2001 | 06:58 PM
JRDNORTAX's Avatar
Hasn't any one got any ideas on this one? I see a number of lookers, but no suggestions yet.
Old Mar 4, 2001 | 07:54 PM
hiofcer's Avatar
The entire unit will need to be replace. A friend of mine had a burnt out neutral light and the entire pod was replaced under warranty. The dealer didn't even program the unit to the actual mileage. It was sitting on all zeros after it was replaced.
Old Mar 5, 2001 | 12:22 PM
Kman's Avatar
Yep, the whole thing will have to be replaced. A friend of mine just had to have it done on his Rancher, with similar symptoms as yours. Don't know the cost, but it was just out of waranty.
Kman
Old Mar 6, 2001 | 04:50 AM
weedman's Avatar
Was your 98 450es involved in the recall? The 98's were recalled do to a battery drain problem. Not sure if they were all recalled but most were.
ScopeZ_
Jul 28, 2015 01:44 AM
ltrmc02
Jul 22, 2015 04:50 AM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
