2005 predator compression
Old Jun 14, 2010 | 08:59 PM
dogspower1's Avatar
Default 2005 predator compression
does anyone know if a predator 500 have a compression relief on it if so how does it work
Old Jun 14, 2010 | 09:11 PM
captjanes's Avatar
i dont think so becasue it is not a high compresion engine. i use to put mine in 3rd gear and push and jump start by myself. and that was when i first bougth her
Old Jun 14, 2010 | 09:20 PM
dogspower1's Avatar
mine starts fine cold runs fine when it gets hot it still runs fine but when its turn off and i go to start it want to kick back like it has to much compression let it set a few mins. it will start but still hard for the starter to turn
Old Jun 14, 2010 | 09:25 PM
captjanes's Avatar
check your air box to see if it is full of oil/water and binding your engine. it could also be your valves need to be adjusted
Old Jun 14, 2010 | 09:26 PM
captjanes's Avatar
i know you said it starts fine cold btu you can check your battery for voltage as well. but i think your safe
Old Jun 14, 2010 | 09:28 PM
dogspower1's Avatar
just checked valves in. are 3 thousands a littel tight ex are right on 10
Old Jun 14, 2010 | 09:35 PM
captjanes's Avatar
well seems like you found your problem i would start with resetting and trying her again. what kind of plug are you running? or just stock??
Old Jun 14, 2010 | 09:38 PM
dogspower1's Avatar
i ahve not even looked at the plug i bought it with a bad top end the guy said the dealer told him,turn out i put a new stater clutch in it fired right up
salixair
Nov 3, 2015 08:25 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Brandon400
Sep 5, 2015 08:44 PM
