chain noise
Old Jun 21, 2010 | 05:59 PM
dave ghard's Avatar
Default chain noise
i have a 2stroke ppolaris400 and i heard a loud snapping noise wen i try to gun it or whenever it is being workd hard so i tightend the chain cuz it was loose and it fixed it but then later on did it agian and is gettin worse and worse i have a feeling maybe the sprocket might be broken im not sure though any help would be appreciated
Old Jun 21, 2010 | 07:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the chain and sprokets from being worn out. also if your riding in mud they will make weird noises from griding rocks and what not. imo
Old Jun 21, 2010 | 11:54 PM
dave ghard's Avatar
yea i have a feeling it is the sprocket for some reason it looks a bit warn out i tightend my chain and went for a ride today and it seems to make that grinding sound mostly if im needing torque like pushing through bush or goin up a steep hill with not much speed is it a hard job to replace the sprocket? and is it a easy part to order do you think .
thnx
Old Jun 22, 2010 | 02:43 AM
Wenty's Avatar
thnx
It's pretty easy to replace...jack up the rear. Pull the right rear wheel off. Pull the hub. take the castle nuts off and slide the sprocket assembly off. Replace and reassemble. The job shouldn't take more than 20 minutes. As long as your at it, replace the front sprocket and chain. The sprocket(s) and chain(s) are readily available...bike bandit, cheap cycle parts, Ebay...etc.
Wenty
Old Jun 22, 2010 | 07:00 AM
Kerbbirds's Avatar
I would replace both sprockets and chain,Ill bet the front one is missing teeth, if you run them too long I've seen the chain break and knock a hole in case of tranny.
Old Jun 22, 2010 | 07:32 AM
scootergptx's Avatar
Supersock
Hired Gun!
You'll be surprised how easy it is to change out both sprockets and chain. Sledpartsguy on ebay was where I got my set up. Standard sprockets and gold o-ring chain. You can upgrade on the chain if you like, but it will make the price go up too.
One thing I'd invest in is a chain breaker. Should be able to get one for about 20-25 bucks. You can get the chain the right length using a bench method, but it sure is a nice thing to have in the tool box when you're chain breaks on a weekend camp out. Toss the extra chain in there too. Broke a chain on a Saturday afternoon, after the shops had closed. Just happened to be with someone who did that and it saved the rest of my weekend.
Old Jun 23, 2010 | 09:08 AM
dave ghard's Avatar
also my buddy has an older kawisaki and it runs perfect right off the start but if u keep rideing it for like 20 mins it dies almosy like its over heating? is there a cooling system i did look like it had a rad
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
