Rims, will they fit?
Old Jun 23, 2010 | 01:09 AM
TNT-Knut's Avatar
Default Rims, will they fit?
Hi!
Will the rims from a 2006 Sportsman 800 efi fit my 2000 Sportsman 500?
I guess the bolt pattern is the same, but what about the offset?
K.
Old Jun 23, 2010 | 08:07 AM
TLC's Avatar
TLC
Maybe the back but not the fronts. The 2000's AWD Hub Assembly causes a larger dia. bolt pattern for the front rim. The 800's AWD Assembly is in the front diff. so the back and front rim bolt patterns are the same.
I,d still at least get the 800's back 12" rims to get away from the 2000's odd 10" rims, it will give you more tire selections for the future. Lots of clearance room at the back to play with so even a different rim offset should not matter.
Old Jun 23, 2010 | 10:28 AM
HTownRider's Avatar
Is the bolt pattern different? Or is it that the front hub sticks out so far that the new model rims won't seat?
I posed a similar question, but about upgrading the hubs on the 02 SP500 to fit the 08 SP800 wheels. I got the same response TLC gave about the AWD being controlled in the hub vs the diff.
IF (and that's a big if) the bolt pattern is the the same, I had come up with a workaround, but haven't gotten a chance to try it out yet. I was going to get wheel spacers and see how well the 08 wheels fit on my 02.
Now all this hinges on the bolt pattern staying the same...unless I got some custom adapters...but that's whole different story.
Anyway, Good luck!
Old Jun 23, 2010 | 11:10 AM
BigDog800EFI's Avatar
Same bolt pattern. Some newer wheels center of the wheels are two small to fit over the older hubs. Newer polaris wheels with the solid centers will not work
Old Jun 23, 2010 | 11:23 AM
HTownRider's Avatar
So, that means my "workaround" might actually work. My 08 SP800 wheels have the center cap on them (not sure about TNT-Knut's 06, though). I could potentially knock those out, use 1" spacers (or possibly 1.5") and hopefully have the wheels fit It would be a good excuse to get bigger wheels on the 02, cuz I don't want it to look funny being extra wide with stock-ish tires. LOL
Old Jun 23, 2010 | 11:31 AM
TLC's Avatar
TLC
Ok, got it here. ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com the 500 and 800 all have a 4/156 bolt pattern front and back,Hub AWD or front diff AWD set up. But the 800s front Hub hole will be to small for the 2000,s larger AWD hub even though the bolt pattens the same.
Good to go for the back wheel swap though.
Old Jun 23, 2010 | 11:36 AM
HTownRider's Avatar
Awesome link TLC. Thanks!
Old Jun 23, 2010 | 02:59 PM
TNT-Knut's Avatar
Thanks for the clarification!
A nice guy is willing to sell these to me at a "give-away" price.
These rims have a solid centers, but I got a friend with a lathe so I'll give it a try..
Anyone done this mod.?
K.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
