Lt 80 no start
Old Jun 22, 2010 | 03:52 AM
joebob57's Avatar
Default Lt 80 no start
I have a 92 Lt80 that has a problem starting sometimes. The starter will not turn when you push the button occasionally. The engine will crank up properly when it does turn over. Battery is good. How do you figure out what part is bad? Joe
Old Jun 22, 2010 | 08:04 AM
95wolv's Avatar
I would start with the parking brake switch down by the foot pedal, if that is not made, it keeps the starter from turning, could be loose, or going bad.
Old Jun 22, 2010 | 08:44 AM
LT80's Avatar
LT80 Expert
Then try a ohm meter on the starter switch. I've seen them go bad.
Welcome to the forums.
Old Jun 22, 2010 | 09:14 AM
95wolv's Avatar
Where are my manners? didnt even see it was your first post, welcome !!
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
