Cold Blooded
Old Mar 3, 2001 | 09:43 PM
sabot's Avatar
SP400 is only a week old but every time I start it cold I have to turn the idle up.Once it warms up I have to turn it back down. The chock is working.My first liquid cooled is this normal.
Old Mar 4, 2001 | 12:06 AM
Todd400's Avatar
Just sounds like a typical 2 stroke in winter temps, Try warming it up a little with the choke on then back it off, try to keep the idle in a set position,that should help.
Old Mar 4, 2001 | 12:20 AM
PolarisMan's Avatar
great idea todd400, but too bad it is a 4 stroke
Old Mar 4, 2001 | 12:27 AM
Todd400's Avatar
My bad, I thought it was a explorer, I guess I should read everything before I open my yap!! Im not much help on the 4 strokes , If its just a week old make the dealer give it a look.
Old Mar 4, 2001 | 10:23 AM
bowtiepu1's Avatar
check your choke cable..i found when running the machine below say 40 degrees mine wouldnt idle at all..i found the choke cable actually was out of adjustment(too loose)..underneath the left plastic panel the cable has an adjuster,try putting it so theres about an 1/8" of play in it and try it out..just follow the cable down and youll find an adjuster under a rubber boot and just take up the slack. the engine in our machines are the same..let me know if it works,good luck
ultangler
Nov 30, 2024 01:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
