07 sportsman 700 no power
my 07 sportsman 700 will run great for a mile or so. Then it starts to back fire and has no power. It runs just like they do when in reverse with the yellow button not pushed in. Im out of ideas thanks.
SAE Code P1260/ blink code 51: Injector 1-open load
SAE Code P0261/ blink code 51: Injector 1-short circuit to ground
SAE Code P0262/ blink code 51: Injector 1-short circuit to battery
SAE Code P1263/ blink code 52: Injector 2-open load
SAE Code P0264/ blink code 52: Injector 2-short circuit to ground
SAE Code P0264/ blink code 52: Short circuit to battery
I found this on the Code 25 in an old thread on here. Hope it helps!
Code 25 is on page 4.19 of the service manual in a special chart for fuel injection. The code means Transmission input-Invalid gear. I would assume it's the input from the switch on the tranny that shows what gear you are in on the speedometer display. It is also supposed to illuminate the check engine light if it's a real problem. My new 800 also had the 25 code after I unhooked the battery to charge it and then reconnected it. You can reset the code by disconnecting the battery for a couple of minutes. I reset mine and it never came back. The shift switch was also functioning fine on mine since the display always showed the correct gear.
bzdok1234
30
Feb 23, 2016 01:55 PM
