pull start stuck caseing broke
Old Jul 8, 2010 | 09:29 PM
stcspiderman's Avatar
Default pull start stuck caseing broke
I went to start my atv up would not start so I pulled started it pull start got stuck. all of a sudden started makeing a bunch of noise I looked at the pull start casing falling apart what is the problem how do I fix this?
Old Jul 8, 2010 | 10:10 PM
TLC's Avatar
TLC
Take it apart, fixed the internal problem that caused the hole, then use "liquid Metal / JB Weld" to fix the hole, or get a cheep used cover off of EBAY.
Old Jul 9, 2010 | 02:46 AM
chuck_raduenz's Avatar
almost look like something broke inside then when you pull started it it wedged it self in there resulting in it poping a hole. just a guess. but take floor board off and remove the 8mm bolts and take a look. make shure its sealed when your done as there are electronic parts in there. i took a cover off of one and there was alota rust in there. not a good thing.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
