Suggestions on noise from CVT area on Sportsman XP?
My belt went bye bye on my last 650 atv trip. I replaced it with a new OEM belt when I got home. After putting it all back together I heard a banging sound coming from the cover at higher rpms. I took it off again and found a small piece of rubber in side the cover. I cleaned it up, ran it with the cover off and then put everything back together. I just took it out again today and heard more banging sounds coming from the same area. Again only at higher rpms both in neutral and in gears.
I took the cover off again but this time I did not see any pieces of belt inside. I put the frame piece back on and the tire & took it out for a mile run this time without the CVT cover on. I did hear the a bang 2 more times but now it seams to be gone. I am going to take it out again tonight before bed.
Any suggestions on what else it may be? Everything else seams ok. No play in the CVT system. I am guessing there were rubber pieces hidden in the system but am not 100% sure?
