ignition key mod?
Old Jul 26, 2010 | 02:01 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Default ignition key mod?
anyone know if you can grind the plastic off the bottom of the key and get it to work both sides?
The top & bottom look identical except the bottom has a a little plastic filling in the key "bumps". If you flip it, everything is exactly the same-
Just curious.
Old Jul 26, 2010 | 07:38 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
I'm assuming that that is not a DS key!?! This forum was so much easier when it was ONLY the almighty DS. So complicated now....
Old Jul 30, 2010 | 03:25 PM
DuneRider650's Avatar
I ride a little here and there......
I wouldnt touch the bottom plastic piece on that key....prob contains the circuit board for the key...remember they are chipped keys now.
Old Jul 30, 2010 | 03:28 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
no- the bottom of the key part is exactly the same on both sides top & bottom- as you cab see in the pics, the key holes are in the same location whether it's up or down, the metal contacts are also the same- it just looks like the factory grinded only one side of the key.
I'm 99% sure you could grind the tiny bit of plastic off the other side and make it work both ways- but I'll wait to hear back from can-am before I do it.
For some reason at night- I always put it in backwards, I'd like to make it work both ways if I can.
Attached Thumbnails ignition key mod?-dscn0229.jpg   ignition key mod?-dscn0230.jpg
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
