I have a 2003 Polaris 700 Sportsman ATV. I would appreciate advice on where the trans
Old Jul 26, 2010 | 02:18 PM
michaelhembury's Avatar
Default I have a 2003 Polaris 700 Sportsman ATV. I would appreciate advice on where the trans
I asked this question the other day and received some advice on where the transmission oil bolt is, but for the life of me I can't find it. It's probably right in front of my face. Second question, How many volts should my machine be putting out on a fully charged battery. I show 14.4 with no load on like lights or the fan, 13 to 13.5 with lights on. Thanks.
Old Jul 26, 2010 | 02:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that would be normal range for the voltage. should be only 1 drain plug onthe tranny w/ a washer too i think.
Old Jul 28, 2010 | 12:24 PM
Big600twin's Avatar
Did you pull the foot well off??? You will not see it until you pull the plastics out of the way.
Old Jul 28, 2010 | 01:13 PM
I did pull off the foot well on the right side (side of the foot brake) There are housing cover bolts, but I just can't locate the drain plug. Maybe I am looking for a larger
bolt like on a car transmission, but I just can't locate it.
Old Jul 29, 2010 | 10:27 AM
Big600twin's Avatar
I'll try to look at mine tonight and see if I can give you more advise. I had the dealer do mine last time so it has been about 5 years since I did it myself.
Old Jul 29, 2010 | 11:17 AM
I found it!! It is right in front of the transmission, below the drive shaft. It's a 9/16 bolt.
There is an oval cut out in the skid plate, and the bolt is right there. Thanks for all your help...Mike
Old Apr 14, 2012 | 02:52 PM
bstaff's Avatar
Default 2003 sportsman 600 transmission drain
it is under the right side. Bolt is actually 7/16, fill plug is 9/16. there is a hole in the skid plate.
neilbedwell
Nov 10, 2018 11:02 AM
3quadbob
Sep 18, 2016 09:46 PM
Thanos
Jul 12, 2015 08:40 PM
yellowpolaris
Jun 21, 2015 11:13 AM
atv1972
Jun 18, 2015 09:31 PM
