97 blaster 200cc no spark
Old Jul 27, 2010 | 07:10 PM
97blaster200's Avatar
Question 97 blaster 200cc no spark
i have a 97 200cc blaster, kick start, and i have no spark. the coil is good (i know this because we jumper wired it from a car battery and touched the wire.) where else could i look? and could it be a faulty on off switch on the handle bars? if so how could i find out? could i by pass it completely by putting a toggle switch?
Old Jul 27, 2010 | 09:20 PM
Terrellster's Avatar
Stator, CDI, Switch..... Pretty much what's left other than spark plug....
The stator coil is known to be a "quitter" on these things.... You can buy the whole new stator or just buy a coil for the ignition side..... I had one quit completely while riding it one day.... About a mile later of pushing the damn thing I was almost ready to part with it..... Lucky it was a flat field, cause it was 100 degrees that day.
One other thing to do a solid check on, is the ground wire at the spark plug coil under the Tank..... Corrosion will drop your spark if there's enough of it there.
Old Jul 28, 2010 | 01:11 PM
the ground is deffinately fine. ive checked and cleaned it all up. the last time i rode it, it died, but i didnt think anything of it, because it died loading it on trailer. ill order a new coil and wire, and see if that works. i need new wire anyway.
thanks
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
zach1106
Jul 31, 2015 01:55 AM
