hoses on carb?
Old Jul 28, 2010 | 05:11 PM
crisatv's Avatar
Default hoses on carb?
hello. does anybody know how to find directions on where to put the different hoses on my carb. i have a 95 polaris scrambler 400 4x4 and i'm putting it together but i don't know what hoses go where. if anybody can help me out i would appreciate it thanx alot.
Old Jul 28, 2010 | 06:00 PM
switzomatic's Avatar
If nobody here has an answer your best bet is getting a manual or the service dept at a dealer might print you a copy for free.
Old Aug 2, 2010 | 06:44 PM
tbsleeper's Avatar
gas line goes on the big nipple on the carb, there another two small nipples and a 2-1 hose that is the overflow for the gas. Connect that up one to the top of hte car one to the bottom. and thats about it for tubes.
Old Aug 2, 2010 | 08:02 PM
JohnnyIron's Avatar
Yup, pretty much all there is, fuel line in, couple of vent lines.
Old Aug 2, 2010 | 10:13 PM
crisatv's Avatar
ok cool. thanx alot. i thaught it would make it run better but it didn't. it still bogs way down when i hit therottle and won't idle. i'm not familiar with these things yet. it has spark and good compression. i cleaned the carb and the float looks good so i don't know. if anybody can help i would appreciate it.
Old Aug 3, 2010 | 08:21 AM
tbsleeper's Avatar
its either to rich or to lean. Try running with the choke on this will let you know if its rich or lean. Then Try moving the needle jet clip to the leanest setting which would be clip on the highest slot if running with the choke makes not difference.
Old Aug 3, 2010 | 09:31 AM
JohnnyIron's Avatar
When you cleaned the carb, did you reset the slide hight? Start by using a .200 dia drill bit placed under the slide. adjust the throttle cable so the slide is just barely gripping the drill bit. Make sure the idle screw is all the way out first. once the slide is set, use the idle screw to adjust idle. (if you can get it started)
What is your air screw set at? A small adjustment of the air screw can make a big differance in some cases.
Did you blow air through all the air ports in the carb? (I'm sure you did,but just checking all the basics)
SDR-II
Sep 29, 2015 01:06 AM
mdrkcckv
Jul 22, 2015 09:10 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
Unzzy66
Jul 11, 2015 10:01 PM
