No Spark
Old Aug 1, 2010 | 08:08 PM
All Scrambled's Avatar
Default No Spark
Hello to all.
Hope some one can help.
I have a 2000 scrambler 500 4x4 and no spark. A side from the simple stuff like fue l/ battery crap. I have checked all the following- new stator, new ignition coil, new CDI box, coil wire good and plug is good also. I am only getting about 314oms from the stator I think it should be up around 430 or so. Does anyone now if it should fire at that reading or is it to low to fire. I also have checked switches and wires that seem to be ok.
Sure hope some one can shed some light on this so I can through some mud.
Old Aug 2, 2010 | 06:38 PM
tbsleeper's Avatar
make sure the point gap on the stator is correct. Im not sure what it suppose to be but hte new one may be incorrect.
Old Aug 2, 2010 | 08:11 PM
JohnnyIron's Avatar
Do you have a manual to see what your ohms should be? Sounds like a manual would have been a cheaper start then buying all those parts.
Old Aug 3, 2010 | 07:35 AM
Sure I do. There is realy no way to test the CDI box. and the ohm's on the stator is right at 314 which the book says it should be 446, I have been told that there is a 10% varence plus or minus. even at 314 ohm's I think that it should at least have a weak spark.
Old Aug 3, 2010 | 07:41 AM
Thanks, I will check on that.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
