2000 Grizzy 600 starting trouble
Im pretty sure the timing is correct, has spark, compression, and is getting fuel. When it fires the motor turns backwords. I put the engine TDC with the "l" mark showing in the bottom sight hole, and on the cam there is a dot on each side in line with the jug, And a dot at top center of center of the shaft....
