1999 yamaha beartracker ?
Old Jul 26, 2010 | 03:02 PM
Mr.Flintstone's Avatar
Default 1999 yamaha beartracker ?
i just bought a beartracker it fired up just fine when i bought it but i went mudding in the rain and now it wont fire it sounds like it wants to but it wont does anyone have any recmmondations and does anyone know the recommended compression its a 250cc
Old Jul 29, 2010 | 07:59 PM
Default update
i just checked my vavle clearance and it was off so i fixed that and it fired and stayed runnin for a couple seconds and it wont fire again but it sounds like it want to but it still wont with ether can someone help me out here
Old Jul 29, 2010 | 08:22 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Carb?
I would start by checking/cleaning the carb/airbox. Sounds like a fuel issue to me...does it have spark at all times? Will it run if you use a starting fluid of some sort?
Mudslinger2
Old Jul 30, 2010 | 06:46 AM
Mudslinger2
its got gas and a good spark and no it wont start with starter fluid thats whats messing me up cause it should and i tore a part the carb and everything looks good inside
Old Aug 3, 2010 | 04:27 PM
bearl_baker's Avatar
check the keyway on the flywheel it could have shered and you are not getting spark at the right time look at the timing marks and the fireing marks
Old Aug 3, 2010 | 09:07 PM
papa hogg scoot's Avatar
Loved
Community Favorite
I have had intake manifolds on yamahas atv,s come apart.. I guess i would inspect intake manifold to see if its loose or has came apart..[it two pieces made into one]... Good Luck...
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Sep 8, 2015 10:51 AM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
