yamaha warrior straight pipes
Old Aug 7, 2010 | 09:23 PM
driftking's Avatar
Default yamaha warrior straight pipes
hi everyone i had a skyway cobra exhaust on my 88 warrior, a few people had told me that that certain exhaust restricts it, so i pulled the screw out of the bottom part of the exhaust and made it just a straight pipe. would anyone recemend just straight a pipe? that would give you more air flow right? more air means more power right? i really like the loud sound though.
Old Aug 7, 2010 | 11:22 PM
Doctorturbo's Avatar
GOT BOOST!
Exhaust needs to be sized correctly to scavenage the exhaust. If done correctly, you can pull a negitive pressure on the pipe to draw out the exhaust.
An open pipe does not do this. That is why headers work on engines. The pressure wave of one cylinder helps draw out the exhaust of the others.
That is why header type exhaust is way better than zoomies on naturally asperated engines.
In short, you will loose a bunch of low end power if you do this. You may make a bit of power on the very top end but I doubt it. It will more than likely put the torque band out of reach of the RPM of your engine and you will loose power all the way through the power band.
Old Aug 8, 2010 | 08:00 AM
Scooter86's Avatar
Knows Old ATV Questions!
Just a bad idea. The loudness is annoying and no longer necessary with the newest gen of exhausts out there. My brother did this same thing to a dirtbike he had, and it noticeably LOST power. If anything, put the internals back in, and save your pennies for a better system.
Old Aug 8, 2010 | 10:54 AM
driftking's Avatar
is a supertrapp a good exhaust?
Old Aug 8, 2010 | 04:16 PM
beastlywarrior228's Avatar
yessss a very good exhaust
Old Aug 8, 2010 | 05:47 PM
91Warrior357's Avatar
yea i think there still pretty good, although not as good as the old ones imo...those were sweet back in the day.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 27, 2015 07:45 PM
