Scrambler engine junk?
Old Aug 9, 2010 | 06:03 PM
hugeyota's Avatar
Default Scrambler engine junk?
I have a 2000 Scrambler 400 4x4. I couldn't get it started so I rebuilt the carb but that was no help. It will fire up on starting fluid and sputter for a couple seconds but wont run on its own. It is getting fuel and spark but I just did a compression test and I only got 30psi. That seems pretty low to me. Maybe I did it wrong. Or maybe that's all there is. Any thoughts on what I should do now. Thxs.
Old Aug 9, 2010 | 06:08 PM
Overdrive's Avatar
No engines will run on less that 80lbs compression. Sounds like it is time for a top end rebuild.
Old Aug 10, 2010 | 06:03 AM
ftwflh's Avatar
Time for a rebuild.If you dont want to rebuild I have a 400 engine list for sale.
Old Aug 11, 2010 | 08:31 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I thought engines need at least 100 lbs. to run?
At least 2-stroke Snowmobiles do .......I never seen a sled run with 80 lbs.?
Caper........
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
Jul 8, 2015 06:13 AM
