03 sportsman 700 no spark
Old Aug 12, 2010 | 08:01 PM
madmax2's Avatar
Default 03 sportsman 700 no spark
hi have no spark on 03 sportsman is it the cdi
Old Aug 13, 2010 | 09:01 PM
Most likely if you have no spark its either the Ducati coil pack or stator have failed. This ignition system has been updated to the complete Kokusan ignition system including the stator,flywheel,cdi,coil and new reg/rectifier,plus harness adapters. Instructions are included in the kit. Its nor cheap,a little over $400,but will solve any future ignition problems. I've replaced quite a few kits. OPT
Old Aug 14, 2010 | 03:48 PM
madmax2's Avatar
thank you
Old Aug 27, 2010 | 12:01 PM
FallstonYJ's Avatar
Is the kit you speak of part#2202603? Do you have any suggestions as to where to get it? I found it on motorsportssupercenter.com but not sure how reliable that seller is. Anyone have any experience with them?
Thanks,
Tom
Old Aug 27, 2010 | 08:38 PM
Correct part number! On line it shows the stator but the description is for the updated kit. Can order at any Polaris dealer,just give em the part number for the kit. Not aware of any other supply sources,but possibly others may know. Kit is not cheap,but has a lot of parts. Little over $400 retail,you may be able to find it a little cheaper?? OPT
Old Aug 28, 2010 | 08:02 AM
FallstonYJ's Avatar
Thanks OPT!
$406 plus shipping is the best I have found so far but again not sure about that on line source. Not worth checking with my local dealer as they would charge list price plus if they thought they could get away with it!!
Old Sep 4, 2010 | 06:55 AM
madmax2's Avatar
Default 03 sportsman 700 keep getting fuel in oil
runs fine but after riding for a few days gain level on dip stick about 3/16" what could be wrong
Old Sep 4, 2010 | 09:47 PM
Kerbbirds's Avatar
needle and seat are bad in the carb, turn the gas off when its not running, you will still have to replace those parts probably. after you replace them start shutting the gas off when not in use and the new one will last longer.
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
