2008 polaris sportsman battery not staying charged?
i own a 2008 polaris sportsman 800 x2. Starting just last night the battery light started coming on going down the trail. now i can not keep the battery charged i have charged the battery fully on a charger then install it back run a few hours just around the yard and the battery goes dead again. does anyone know of what could be causing this problem?
Check that battery connections/grounds are good. Does it sit for long periods between rides? Wouldn't hurt to take it to someplace that can test it. May be that the battery has a dead cell so it will take a charge but not hold it long. If that ends up being the case pick up a trickle charger and keep it on when not in use. Just picked one up for $3.99 with a coupon from Harbor Freight(currently have two but will get a few more for all my machines). Greatly extends battery life. If it's not the battery/connection then I agree with boba on checking the rectifier and continuing from there if the problem isn't found.
Thank you for your reply's i run my atv every weekend and usually dailey depending on what i feel like driving to work. so it harldy sits a long time. i ordered a new regulator today could it possible be anything else while i have it taken apart?
Just make sure to check the easy stuff(connections/output/battery) before ordering more parts. I'm sure they aren't cheap. I forgot to ask what your running for accessories. If using your lights/winch/etc keeping a trickle charger on will help if it's a battery issue. The charging system won't keep it at 100% especially if using lights/winch. Hopefully it's something simple(and inexpensive).
thank you i check those and even replaced the battery with a newer one and within a hour or two of running it would die also. It has a winch but since owning it i have only used it twice and that was a long time ago. i do run the lights on it everytime we go out but its a must since we ride at night. i found a regulator for 70.00 so it was not to much out of my budget and it had a warranty so if it doesnt fix the problem i can send it back. i had a problem awhile back with it skipping going down the trail could the battery not getting a full charge be the problem with that?
Did that fix your problem? I have a Polaris Hawkeye 07 I just got and im having the same issues.
whitty
67
Feb 24, 2021 02:52 PM
Mphillips
Jul 29, 2015 08:53 PM
Schneider
Jun 4, 2015 11:37 AM
