2009 rzr
Old Aug 18, 2010 | 08:17 AM
gat222's Avatar
Default 2009 rzr
I have a hole in rear cv boot, in addition at slow speed 5 mph or so there is a clicking noise...any thoughts what it could be...perhaps wheel bearing?? Any help would be appreciated.
Gat
Old Aug 18, 2010 | 08:34 AM
EPIChad's Avatar
Usually the clicking comes from a CV Joint. And more likely the one with the damaged boot. The hole in the boot will allow dirt and water into the joint and will normally damage it.
You can try cleaning the joint, install new grease, and a new boot and see if it clicks. Usually once it clicks its time to replace.
Old Aug 18, 2010 | 08:58 AM
gat222's Avatar
Default Cv joint
Thank for the reply...Is the joint easier to replace than a bearing... just curious?
GAT
Old Aug 18, 2010 | 09:38 AM
Big-O's Avatar
I have never looked at a rzr but I think it should be close to the same as this.
chuck_raduenz gave a great brake-down in this post.
http://forums.atvconnection.com/pola...ighlight=joint
hope this helps
Old Aug 18, 2010 | 05:48 PM
hallj86's Avatar
umm the clicking means the cv is shot you need a new one dont just replace the boot the hole has been there a long time and the cv is shot
Old Aug 18, 2010 | 08:05 PM
Overdrive's Avatar
If the inner joint is clicking it could run for a long time before it goes. The outer one will not last long.
Old Aug 20, 2010 | 06:51 PM
FunRide's Avatar
Originally Posted by gat222
I have a hole in rear cv boot, in addition at slow speed 5 mph or so there is a clicking noise...any thoughts what it could be...perhaps wheel bearing?? Any help would be appreciated.Gat
Replace junk parts and look into better protection for the CVs. Also avoid nasty logging trails with death spikes shooting up from the soil. It's just not worth it. There's lots of nasty terrain in the east from logging operations that will ruin CV boots in no time. If you ride in conditions like that you need to look into better protection (front and rear).
You don't want stuff breaking on you while you're 30 miles deep into the chit.
Old Aug 21, 2010 | 09:37 AM
Kerbbirds's Avatar
you can get a complete axle from the cv-man 1-800-338-2326 for less than the cv joint from polaris.
cboler9
Sep 24, 2015 08:35 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
YFZsandFreak
Jul 4, 2008 12:31 PM
