no fuel
Old Aug 19, 2010 | 11:17 AM
luke21er's Avatar
Default no fuel
Hey there, I have a 04 polaris sportsman 500ho. When I first fire it up it runs fine and then after it idles for about 5 minutes it stalls out. Then it wont start back up, the problem is it isnt getting any fuel. So I got a different fuel pump and put it on but it does the same thing. Any suggestions? Or is it maybe that both pumps are bad?
Old Aug 19, 2010 | 05:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
this not an efi correct? if not check the float level or for a plugged idle circuit or jet. also check to make sure the vent lines form the tank and carb arent blocked or pinched.
Old Aug 20, 2010 | 05:36 PM
Overdrive's Avatar
Carb vents.
Old Aug 21, 2010 | 06:15 PM
Kerbbirds's Avatar
Loosen the gas cap , if it runs its the gas tank vent on top of the tank under the plastic if its sat for awhile the main jet or pilot jet in the carb could be plugged
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
