2008 Polaris 700 EFI x2
I'm having a problem with the engine cutting out above 25mph or as I rev it in neutral. Check engine light has come on and I was able to get 3 codes out of it.. 51, 52, and 54. The first two point to electrical problems w/ injectors and the 54 is not in my manual. I have recently had some trouble with the battery connection where I had to wiggle the wires to get it to start. I am wondering if these could be related. I noticed when I revved it in the shop, the display panel would dim significantly when it was sputtering and cutting out. Any help would be appreciated.
Thanks
Thanks
Yes it's related. The battery contacts need to be tight and clean. These bikes need constant electrical power or they will not run right. You will have stumbling, backfires, stalling and hard starts. I found this out the hard way, after cleaning and tighting down my battery cables it has been trouble free.
I just googled Polaris code 54 and found this on another forum
Diagnostic "Blink Codes" Chart
21 - Loss of Synchronization
22 - TPS Circuit: Open or Short to Ground
22 - TPS Circuit: Shot to Battery
23 - RAM Error: Defective ECU
25 - Transmission Input - Invalid Gear
26 - Vehicle Speed Sensor - Implausible
41 - Air Temp Sensor: Open or Short Circuit to Sensor Voltage (ECU)
41 - Air Temp Sensor: Short Circuit to Ground
42 - Engine Temperature Sensor Circuit: Open or Short to Battery
42 - Engine Temperature Sensor Circuit: Short to Ground
45 - Barometric Pressure Sensor: Circuit Low Input
46 - Barometric Pressure Sensor: Circuit High Input
51 - Injector 1: Open Load
51 - Injector 1: Short Circuit to Ground
51 - Injector 1: Short Circuit to Battery
52 - Injector 2: Open Load
52 - Injector 2: Short Circuit to Ground
52 - Injector 2: Short Circuit to Battery
54 - Engine Temperature Lamp: Open Load
54 - Engine Temperature Lamp: Short Circuit to Battery
54 - Engine Temperature Lamp: Short Circuit to Ground
55 - Diagnostic Lamp: Open Load
55 - Diagnostic Lamp: Short Circuit to Ground
55 - Diagnostic Lamp: Short Circuit to Battery
56 - Pump Relay: Open Load
56 - Pump Relay: Short Circuit to Ground
56 - Pump Relay: Short Circuit to Battery
58 - Cooling Fan: Open Load
58 - Cooling Fan: Short Circuit to Ground
58 - Cooling Fan: Short Circuit to Battery
61 - End of Diagnostic Check
seems all your codes have to do with your battery issue
bzdok1234
30
Feb 23, 2016 01:55 PM
