Non4x4 scrambler to 4x4 scrambler 400?
Old Aug 23, 2010 | 01:29 PM
Questkid87's Avatar
Default Non4x4 scrambler to 4x4 scrambler 400?
How much money would it take to convert a no 4x4 400 scrambler to a4x4 and how hard is it to do
Old Aug 23, 2010 | 07:05 PM
Bout like changing a Chevy to a Cadillac!! If older chain driven model the trans shaft is different with an outer sprocket to run the center chain,PLUS you have to have the center and front ecentric assy's,Plus both struts have to be changed out to awd models!! OR you can change to a later transmission with the propshaft (needed) to the front gearcase(needed) along with the struts and both front driveshafts!! Just enjoy what you have OR trade for a 4 wheel drive! OPT
Old Aug 24, 2010 | 01:50 AM
TLC's Avatar
TLC
A 4wd gives you the ability to go deeper and further before getting stuck.
Old Aug 24, 2010 | 07:54 PM
!!!! Great quote!!! I might steal that one from you!! OPT
Old Aug 25, 2010 | 07:12 PM
4getful2's Avatar
if the motor on your 2 wheel drive is in good shape and you have a lil knowledge of nuts and bolts then you should start looking on craigslist for a donor vehicle(a 4wd scrambler that has a junk motor)
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
