50 hour service //good and bad
Old Sep 7, 2010 | 10:03 AM
colt2245p's Avatar
Default 50 hour service //good and bad
well i have now 50 hours and about 700 miles on the machine.....so far the motor has been flawless, gobs and gobs of power.....now for the bad findings.........left outer front brake pad wore down to the metal the other 3 brake pads still over half.......both upper ball joints have play in them......both front lower control arms at the frame mount have play in them...the lower rear control arms at he frame are loose also and both top and bottom mounts at the bearing housings are loose also.....this bike has not seen any mud holes either.....mainly cuz there is no mud holes (very dry here) most of the miles have been old dirt/gravel country roads and some moderate trails.....now that i have vented i must order parts.......4 months 50 hours ....not a happy polaris day here........
Old Sep 7, 2010 | 10:21 AM
unit6666's Avatar
I've seen it a 100000 times.. Sorry
Old Sep 7, 2010 | 02:19 PM
PWN's Avatar
PWN
Have you ever greased them? After 700 miles they are probably starving...
Old Sep 7, 2010 | 02:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i doubt there is many grease fitting on it as the new ones dont have many at all.
Old Sep 7, 2010 | 02:24 PM
colt2245p's Avatar
yes they were all greased at about 15 and 30 hours......and yes they had grease in them when i pulled them apart.....the plastic bushings show wear on one side and the metal rod where it rides has wear on it also
Old Sep 7, 2010 | 02:26 PM
colt2245p's Avatar
stendori the new ones (850xp) have 4 per side on the front and 5 per side on the rear......and they are a real beatch to get to....i had to make a 90 degree tip to get to them. theres a total of 19 fittings i have found to grease
Old Sep 8, 2010 | 08:04 AM
PWN's Avatar
PWN
That really sucks that they didnt last that long. Atleast they are not that hard to change.....Just MESSY.
Customer Service #1
May 15, 2020 08:46 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
