middle drive flange bolt keeps loosening
i found oil leaking out at transfer case flange area. i removed u-joint and found that the nut was loose. i replaced seal, nut and washer. i torqued new locknut nad reassembled with u-joint. i then found after riding for about 2 hours that the nnut loosened up again and oil was leaking out. i had to tap nut snug to get out of woods. is this a common problem? the only other thing i can think of is to apply locktite to it but think it will do it again.
skeets44
Jul 17, 2015 01:04 PM
