middle drive flange bolt keeps loosening
Old Sep 8, 2010 | 08:44 PM
dlguitarman's Avatar
Default middle drive flange bolt keeps loosening
i found oil leaking out at transfer case flange area. i removed u-joint and found that the nut was loose. i replaced seal, nut and washer. i torqued new locknut nad reassembled with u-joint. i then found after riding for about 2 hours that the nnut loosened up again and oil was leaking out. i had to tap nut snug to get out of woods. is this a common problem? the only other thing i can think of is to apply locktite to it but think it will do it again.
Old Sep 9, 2010 | 06:42 AM
Terrellster's Avatar
Use the red loctite and make sure and put enough on to leave a visible sign it's there... that way you don't spend another time wondering why you can't get the nut and bolt off.... The red stuff is a higher temp loctite and does require some significant heat to make it release without too much trouble. If that doesn't work, then it looks like time to call a priest.... Exorcism coming soon..... or maybe it's gremlins....
Old Sep 9, 2010 | 11:28 AM
Dirtjunkie85's Avatar
I agree go with the red lock tite and it should solve the problem!
Cummins Driver
Sep 11, 2019 01:22 PM
ghost civic
Jul 30, 2015 04:09 PM
carolinabomb
Jul 26, 2015 08:40 AM
skeets44
Jul 17, 2015 01:04 PM
Unzzy66
Jul 11, 2015 10:01 PM
