02 scrambler 4004x4 hub problem
Old Sep 10, 2010 | 06:20 PM
itstillruns's Avatar
Default 02 scrambler 4004x4 hub problem
I have a 02 scrambler 400 4x4.one side doesnt lock in 4x4.The other side I can barely pull the armature plate off the hub but bad side I can pull the plate fairly easy. Both sides read same ohms and volts.any ideas? there was metal shavings from the armature plate on bad side.??
Old Sep 10, 2010 | 07:02 PM
ftwflh's Avatar
Try plates on opposite sides and see how it acts.
Old Sep 10, 2010 | 08:19 PM
I tried the entire hub,cage plate etc on other side,works fine.Is there a tight tolerance on the metal rings that the magnet sits in? I know those can wear on a Sportsman center diff.
Old Sep 10, 2010 | 09:03 PM
ftwflh's Avatar
Yes the clearance is very tight.Not sure but .002 sounds about right.Someone may have the exact setting
Old Sep 11, 2010 | 04:36 PM
anyone know if a 99 strut and magnet will fit in my 2002?
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 13, 2015 05:11 PM
