DS won't start!!!WTF!!!!
Old Sep 11, 2010 | 05:37 PM
cucuy's Avatar
Default DS won't start!!!WTF!!!!
Quick question guys,04 baja,just did the crank bearings and rings,ran slightly rough for a while,adjusted valves,now it won't start!!!
Got spark,got fuel,timing is right on!!!cranks but wil not fire!!
Any leads??? all help is greatly apreciated!!!!!!
By the way!! first rotax ds 650 repair!!
Old Sep 11, 2010 | 07:28 PM
dirtjunkie's Avatar
Spray some starting fluid in it, see if it will fire if it does time to clean the carb real well, if not you have a timing issue
Old Sep 12, 2010 | 09:43 AM
brian 68's Avatar
are you sure you got the cams lined up right? if it ran before the valve job you might be off a tooth . did you lock it at tdc when you set it?
Old Sep 12, 2010 | 01:48 PM
cucuy's Avatar
Default mmm!
I took it apart again,transfer the parts and cams from my other motor,I figured is the valves not adjusted properly,but still won't run,the cams are lined up,crank is at tdc,both facing outward,cranks and no start,it will throw a crazy misfire once in a while,got spark and fuel!!!
Old Sep 12, 2010 | 08:35 PM
cucuy's Avatar
Cotter pin at crank for magneto was sheared off!
put a new one,still does a misfire when cranking but nothing!
cams are line up,tdc ok,is there a mark on the magneto???
It seems out of timing but the marks are all there!!!
Old Sep 12, 2010 | 08:37 PM
cucuy's Avatar
The cam decompressor broke,small piece at l/s crank bearing,locked the engine,was running b4 all this happened!
Old Nov 6, 2010 | 08:50 PM
Trevorh19's Avatar
Default Valves?
Hey, Mine was doing the exact same thing but it got progressivly worse untill the point where i had to pullstart it or spray gas in the carb to start it, it was the valves out of adjustment i had them adjusted to proper spec and it fired and has ran perfect since until today when it started spraying oil out the vent tube but anyway make sure the valves are properly adjusted.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
