Anyone seen a problem with...
Old Sep 12, 2010 | 03:43 PM
Shotgun Kennel's Avatar
Default Anyone seen a problem with...
I am brand new to this forum but would like to find out if anyone has had any issues with burning belts on the newer Polaris when pulling brush hogs or doing some food plot work pulling implements?
I have a "96"400 Sportsman and it really is not designed to do this in my opinion.
Thanks for your help ahead of time.
Old Sep 12, 2010 | 03:49 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Are you using low range? If you don't already know, when working the machine at slow speeds it is advised to use low range.
Old Sep 12, 2010 | 04:05 PM
Overdrive's Avatar
Thats right. You will smoke a belt every time in high.
Old Sep 12, 2010 | 07:20 PM
Using low range, if it doesn't have the traction to pull it will dig 4 holes in the ground before it burns a belt.
Old Sep 16, 2010 | 06:54 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
He is asking about the newer Polaris?
His Quad is a 1996. He must be wanted to buy a new one and thinking about belt issues, just like I did back in 2006, Just make sure you get one with low gear if you working the Quad with attchments.
...Caper.....
Old Sep 16, 2010 | 08:06 AM
TLC's Avatar
TLC
like mentioned. the ATV will dig itself 4 holes before burning a belt in low range. We go heavy all the time.
Old Sep 16, 2010 | 08:15 AM
switzomatic's Avatar
Ditto on low range. I can pull my 14' trailer loaded all day long without issues. Replaced one belt in 1800 miles on my lifted/modded 05 800 and have yet to change a belt on my 09. My machines work/play a lot. Run tracks and plow all winter. My wheeler rarely sees high range.
Old Sep 16, 2010 | 12:53 PM
JK500sp's Avatar
I always use low range but how do you guys keep the suspension from bottoming out. When I hook up my trailer just to move it around the yard. ( to keep my truck from making ruts ) My SP500HO pulls great but bottoms out in no time its terrible.
Old Sep 16, 2010 | 01:13 PM
TLC's Avatar
TLC
I put the HD springs on as soon as I bought it,on the softest setting there like the stock springs on the stiffest setting. I tried the stiffest setting one time but its too stiff. Do you atleast have your spring set on the stiffest setting? I think the ATV comes set at the softest from the factory.
Old Sep 16, 2010 | 01:25 PM
JK500sp's Avatar
are they Polaris HD or is HD a brand of its own?
