Drill ricochet skids
I wouldn't worry about it. I believe Ricochet uses aluminum. The metal that a hole saw is made out of will drill through thin steel. I don't think nice soft aluminum should be a problem. I've used hole saws on many steel doors (with foam cores) and they still are sharp. I imagine they'll dull eventually but mine haven't yet. I usually us Blue Mol or Vermont American.
Thx Moose and Wire.
Yep I'll probably use buddies drill press for a cleaner cut.
Anyone else drill oil drain holes in there skids for easy fluid changes.
Buddy has ricochet on his 700 grizz and they came with pre drilled holes
Oct 10, 2015 10:20 AM
ElementzzofStyle
Aug 29, 2015 10:45 AM
