Drill ricochet skids
Old Sep 20, 2010 | 02:59 PM
MudAddict's Avatar
Default Drill ricochet skids
Anyone use a hole saw to drill out ricochet skid plates?
For front and rear diff and tranny. It would make it easier for changing fluid. 09 850 XP
Old Sep 20, 2010 | 05:03 PM
I wouldn't worry about it. I believe Ricochet uses aluminum. The metal that a hole saw is made out of will drill through thin steel. I don't think nice soft aluminum should be a problem. I've used hole saws on many steel doors (with foam cores) and they still are sharp. I imagine they'll dull eventually but mine haven't yet. I usually us Blue Mol or Vermont American.
Old Sep 20, 2010 | 07:23 PM
wirehair1's Avatar
What he said, clean up the edges with a Dremel and a sanding drum.
Old Sep 20, 2010 | 09:04 PM
MudAddict's Avatar
Thx Moose and Wire.
Yep I'll probably use buddies drill press for a cleaner cut.
Anyone else drill oil drain holes in there skids for easy fluid changes.
Buddy has ricochet on his 700 grizz and they came with pre drilled holes
Alex G.
Sep 11, 2017 11:38 PM
Oct 10, 2015 10:20 AM
ElementzzofStyle
Aug 29, 2015 10:45 AM
95wolv
Jul 21, 2015 12:25 PM
