Need rear end parts Polaris
Old Sep 22, 2010 | 04:42 PM
teugene@shaw.ca's Avatar
Default Need rear end parts Polaris
Hello I'm new to the site. Is this where I should look for parts for my ATV. I have a Polaris Magnum 500 1999. I am looking for the rear axle, as well as the Bevel gear that fits over the axle located inside the crown gear. I'm not too sure as to whether any Magnum rear differential would fit.
Tim
Old Sep 22, 2010 | 06:40 PM
TLC's Avatar
TLC
Id check E Bay, these ATVs use the same 5131862 axle
2001 ATV MAGNUM 325 2X4 SWING ARM/REAR GEARCASE MOUNTING - A01CB32AA
2001 ATV 325 MAGNUM 2X4 HDS SWING ARM/REAR GEARCASE MOUNTING - A01CB32AA
2001 ATV MAGNUM 325 4X4 SWING ARM/REAR GEARCASE MOUNTING - A01CD32AA
2001 ATV MAGNUM 325 4X4 MOSE SWING ARM/REAR GEARCASE MOUNTING - A01CD32AA
2001 ATV 325 MAGNUM 4X4 HDS SWING ARM/REAR GEARCASE MOUNTING - A01CD32AA
2001 ATV MAGNUM 500 SWING ARM/REAR GEARCASE MOUNTING - A01CD50AA
2001 ATV 500 MAGNUM 500 HDS SWING ARM/REAR GEARCASE MOUNTING - A01CD50AA
2001 ATV XPEDITION 325 SWING ARM/REAR GEARCASE MOUNTING - A01CK32AA
2001 ATV XPEDITION 425 SWING ARM/REAR GEARCASE MOUNTING - A01CK42AA
2000 ATV MAGNUM 325 2X4 SWING ARM/REAR GEARCASE MOUNTING - A00CB32AA
2000 ATV 325 MAGNUM 2X4 HDS SWING ARM/REAR GEARCASE MOUNTING - A00CB32AA
2000 ATV MAGNUM 325 4X4 SWING ARM/REAR GEARCASE MOUNTING - A00CD32AA
2000 ATV 325 MAGNUM 4X4 HDS SWING ARM/REAR GEARCASE MOUNTING - A00CD32AA
2000 ATV 325 MAGNUM 4X4 HDS II SWING ARM/REAR GEARCASE MOUNTING - A00CD32AA
2000 ATV MAGNUM 500 SWING ARM/REAR GEARCASE MOUNTING - A00CD50FB
2000 ATV MAGNUM 500 EB SWING ARM/REAR GEARCASE MOUNTING - A00CD50FB
2000 ATV 500 MAGNUM 4X4, HDS SWING ARM/REAR GEARCASE MOUNTING - A00CD50FB
2000 ATV 500 MAGNUM 4X4, HDS II SWING ARM/REAR GEARCASE MOUNTING - A00CD50FB
2000 ATV XPEDITION 325 SWING ARM/REAR GEARCASE MOUNTING - A00CK32AA
2000 ATV XPEDITION 425 SWING ARM/REAR GEARCASE MOUNTING - A00CK42AA
1999 ATV MAGNUM 500 SWING ARM/REAR GEARCASE MOUNTING - A99CD50AA
These ATVs use the same 3233576 Gear
2000 ATV MAGNUM 325 2X4 REAR HOUSING - A00CB32AA
2000 ATV 325 MAGNUM 2X4 HDS REAR HOUSING - A00CB32AA
2000 ATV MAGNUM 325 4X4 REAR HOUSING - A00CD32AA
2000 ATV 325 MAGNUM 4X4 HDS REAR HOUSING - A00CD32AA
2000 ATV 325 MAGNUM 4X4 HDS II REAR HOUSING - A00CD32AA
2000 ATV MAGNUM 500 REAR HOUSING - A00CD50AA
2000 ATV MAGNUM 500 EB REAR HOUSING - A00CD50AA
2000 ATV 500 MAGNUM 4X4, HDS REAR HOUSING - A00CD50AA
2000 ATV 500 MAGNUM 4X4, HDS II REAR HOUSING - A00CD50AA
1999 ATV MAGNUM 500
Check this site for Part #s just to make sure. OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
MikeyBoyesq
Nov 27, 2020 02:44 PM
scaldwellk
Jun 19, 2015 05:08 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
