valve adjustments
Old Sep 25, 2010 | 02:35 PM
johnnyjaws's Avatar
Default valve adjustments
is there any posts or videos on valve adjustments 0n a 06 polaris 500 sportsmen!
Old Sep 25, 2010 | 03:34 PM
TLC's Avatar
TLC
I would try You tube, never did it but I hears its not a bad job.
Old Sep 25, 2010 | 05:56 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Not a bad job at all. All you really need to do is pop off the side inspection plate, roll the engine over with the pull starter to TDC. (there will be marks you can see) Pop the valve cover and do your adjustments. Pretty easy compared to some like my 325 magnum where you have to pull the tank to get at the intake side due to lack of room.
Old Sep 26, 2010 | 04:10 AM
MNpinetree's Avatar
YouTube - Polaris ATV Maintenance & Repair Tips : Polaris ATV Valve Adjustment Tips
Old Sep 26, 2010 | 05:01 PM
reno82's Avatar
here are some photos Polaris Sportsman 500 valve-adjustment pictures from motorcycles photos on webshots
Old Sep 27, 2010 | 06:07 AM
ftwflh's Avatar
Simple job after you get the plastic and gas tank off .
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
