CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
DS650 battery goes dead when off.
Old Oct 2, 2010 | 09:14 AM
Sport400inOH's Avatar
Default DS650 battery goes dead when off.
In less than a week my battery will go from fully charged to only clicking when I hit the starter. I just replaced the battery (again) since my charger has found an open(or sulfated) cell and the battery voltage hovers in the 10.5v range.
After much researching and reading (Mostly here), I started by sanding and tightening my ground points. With the battery connected and the DS running, I get between 14.5 and 14.74v depending on if I have the lights on or not, so the charging system is working.
I found that, in order to test for a draw, I need to connect the positive side of the battery to the DS positive cable and leave the negative side disconnected. I have tested the voltage between the negative battery terminal and the negative wire (With the quad off). I am getting around 11.9 - 12.2v. That seems to be a hefty draw. When I disconnect the rectifier plug and retest, the voltage reads zero.
Does this mean my rectifier is bad??
slowgsxr97
Mar 18, 2022 03:40 AM
cody500ho
14
Aug 14, 2015 05:03 PM
ScopeZ_
Jul 28, 2015 01:44 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
