CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
I think I broke something.... any ideas?
Old 10-23-2010 | 11:26 PM
Cammer's Avatar
Default I think I broke something.... any ideas?
Hey guys! i know I am asking a question about my daughters Suzuki but you always have the
answers so here goes. So I am adjusting the clutch on my LTZ 400 tonight and the strangest thing happened. The quad was lurching when we start it even with the clutch fully in. So I decided to change the puller one tooth to help the clutch engage fully. When I disconnected the cable at the motor end the gear seemed to disengage inside the motor. Now it has no tension and the clutch won't return when you let go. I did not put much pressure on the cable clasp/gear when I disconnected the clutch cable so i am very perplexed why it turns so easy and doesn't return when you let go of the clutch lever. I have read that this has happened to other but no one has posted a fix.
Please help.
Old 10-24-2010 | 01:56 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
I hope it's not what happened to me when I had almost the same issue. If it's the same set-up as the DS you may have broken one of the teeth off of the actuator arm or the actuator rod. I've done both while running TVI 80% springs. The arm is what pulls the clutch basket out when the rod turns via the lever. At different times I sheared two or three teeth off each of those.
Hope that helps some. Good luck with it.
ride26
10-22-2015 04:09 PM
Hunter100us
10-07-2015 11:46 PM
robert301972robert
08-30-2015 11:34 AM
DeFox500
07-26-2015 06:32 PM
mdrkcckv
07-22-2015 09:10 AM
Quick Reply: I think I broke something.... any ideas?
