05 Trailblazer Clunk
Old Oct 3, 2010 | 08:06 AM
harricanfloyd's Avatar
Default 05 Trailblazer Clunk
I have a buddy who just bought an 05 TB. It wasn't what it looked like in the pictures....but he bought it anyway. So far he needs front hubs( when you jack it up the front wheels wobble.....and yes the castle nuts are tight), tightened the rear hubs, starter sometimes "clicks" when you hit the button, and the rear shock bottoms out with no effort at all I think it's minor sh**** but he thinks he bought a POS. Biggest question is What's the clunking in the rear. I did find a kink in the chain, but I think I was able to "lube" it out.
Old Oct 3, 2010 | 10:02 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it sounds like he didnt pay attention much to what he was buying. anyways it sounds like the front bearings are gone. do not overtighten the nuts as it puts too much pressure on the bearings. check the connections for the starter cables and solenoid cables to make sure they are tight and not corroded. is the battery charged up good? so what is it for a bike if it's not a trail blazer?
Old Oct 5, 2010 | 07:01 PM
dirtsnow's Avatar
when my tb had a clunk in the rear end it needed a new chain & sprockets (if u have
to lube it heavy alot to stop the clunking that means they are bad) I got my set off
ebay & saved alot of money!
Old Oct 5, 2010 | 07:16 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Front wheel bearings, chain and sprokets sounds like the required items. All are normal wear items with machines 5 to 10 years old. Be sure to change all the fluids (engine oil and transmission).
Old Oct 6, 2010 | 07:06 PM
TrailblaznSonny's Avatar
I had an 02 same thing.. Chain and sprokets. Hard to keep the chain tension right and keep well lubed. Fun bike. I loved mine.
TBS
Old Oct 18, 2010 | 06:18 AM
TBS
Yah! thanx for the info Sonny.....LOL my 03 just started doing the samething. I was rippin down the path and all of asudden, clunk Waaaaaah clunk! I just bought a chain+sprocket set.....we'll see if it cures the problem!! Funny you mention the chain tension....my 01 is de-rainling the chain for some reason!
Old Oct 18, 2010 | 09:31 AM
TLC's Avatar
TLC
The front wobble must be bearings $9 each. Do not tighten nut over 14 ft/lb. Starter may just be a bad connection or has a sticky brush inside that needs cleaned and lubed to free it up again. Both easy cheap jobs.
If I bought a used chain drive ATV or motorcycle I would want two new sprockets and a chain just for piece of mind.
Chain $50 rear sprocket $40 OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
front sprocket $40 also.
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
brad wheeler
Jul 13, 2015 11:19 PM
