'93 350L slipping in LO. What is needed
Old Oct 5, 2010 | 12:18 AM
ihcman's Avatar
Default '93 350L slipping in LO. What is needed
I have a '93 350L Trailboss 4x4, and after riding on Sun, Lo starting slipping.
High Range seems to be just fine, just Lo will rev without gaining speed.
I did ride most the day in LO, as speed did not need high. Did I overwork the transmission, and what could I have burned out?
What parts would be needed to replace?
Also I the battery is gone and broke the pull start cord, how hard is it to replace.
Thanks,
Brian
Old Oct 5, 2010 | 06:02 AM
ftwflh's Avatar
Sounds like a secondary clutch issue.At least that is the cheapest easiest fix.Check it out first.
Recoil isnt that bad to fix.Read the manual and follow instructions
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Bm400ex
Jun 22, 2015 09:16 AM
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 28, 2015 09:47 AM
