1995 Polaris 350l 2x4
Old Oct 14, 2010 | 12:13 PM
Polaris Wheeler's Avatar
Unhappy 1995 Polaris 350l 2x4
Can anyone help with the problem of engine stalling when throttle is released. There is a electrical swith in the throttle housing that seams to cut power to the engine. I believe it is just an adjustment to the throttle cable needed. I do not have a repair manual yet as I just purchased the machine.
Old Oct 14, 2010 | 03:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the etc is made too stop the rpms when the throttlw is stuch open. the correct settting is 1/8" gap in the cable slack in the throttle.
Old Oct 14, 2010 | 03:12 PM
Smile
Thanks, can you tell me where I would measure the gap in the cable as I do not have a repair / service manual yet.
Old Oct 14, 2010 | 05:43 PM
Overdrive's Avatar
Just remove all the slack.
Old Oct 14, 2010 | 07:57 PM
4getful2's Avatar
you'll need to remove the black plastic cover on the handlebar, look inside and yooiu will see 2 wires with contacs, they most likely are touching, adjust the cable so that there is 1/16 to 1/8 in. gap . you will see that slack adjutment in the cable about halfway down the handlebar. this adjustment needs to be readjusted at each time the engine idle is changed.
Old Oct 14, 2010 | 08:07 PM
Overdrive's Avatar
If it was mine I would do away with it. It is just something else to screw up.
Old Oct 15, 2010 | 06:08 AM
Smile Polaris 350L
I think you are right. Sometimes electronic problems are hard to track down and fix. Thanks for the reply.
Old Oct 15, 2010 | 05:44 PM
ftwflh's Avatar
if you ETC switch is bad drop me a PM
Old Oct 16, 2010 | 04:11 AM
TLC's Avatar
TLC
Polaris ATV Thumb Throttle Maintenance Tips: Polaris ATV Maintenance & Repair Tips | eHow.com
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
cornermike
Jul 30, 2015 06:37 AM
