speedometer
Old Oct 19, 2010 | 09:41 PM
beagleboy's Avatar
Default speedometer
2003 sportsman 4x4
all gauges work except the speedometer. Do I need a new cable or could something else be wrong. can mud stop up the cable? thanks
Old Oct 19, 2010 | 09:47 PM
TLC's Avatar
TLC
The speedo is electric not cable operated, If the AWD still is working on the ATV then the "Hall Effect" sensor by the right front brake rotor is shot or the wire from the sensor has a bad connection to the speedo. The senors are $50 and easy to change. Part #28 in Fiche http://www.cyclepartswarehouse.com/f...003&fveh=30450
Old Oct 20, 2010 | 07:28 PM
sammydogs64's Avatar
TLC has gotten it correct, common problem.
Old Oct 21, 2010 | 12:02 AM
chuck_raduenz's Avatar
mine whent out the odo, speedometer stoped working the rest worked. you can test the speed sensor.
rawbdiggity
Sep 7, 2015 12:05 PM
byronman
Sep 6, 2015 06:34 PM
400H0
10
Aug 20, 2015 07:34 PM
chuck1177
Jun 30, 2015 09:52 AM
nevermiss
Apr 1, 2000 10:53 AM
