front end Whining noise
Old Oct 24, 2010 | 10:27 PM
Rustybdd881's Avatar
Default front end Whining noise
I have a 1996 Polaris Magnum 425 4x4. I have a whining noise coming from the front of the atv. I have adjusted the chains, made sure the front tightener is lubed, but still makes the noise. I wonder if anyone thinks the bearings in the tightener could be bad? or could it be another problem. Thanks!
Russ
Old Oct 24, 2010 | 11:01 PM
MECHANIKE's Avatar
welcome to the forum,,,,,maybe change the front gearbox gearoil,check your front hubs for level.make sure there is no play.
Old Oct 24, 2010 | 11:09 PM
MECHANIKE
Thanks for the welcome! When you say change the gearbox, are you talking about the tightener unit itself? Thanks!
Russ
Old Oct 24, 2010 | 11:18 PM
MECHANIKE's Avatar
the gear oil in the gear box,plus make sure the front awd wheel hubs are tight and have the proper amount of hub fluid.
Old Oct 24, 2010 | 11:30 PM
MECHANIKE
Got it! I will check that tomorrow. Thanks for your help!
Russ
ronnierhino06
Nov 9, 2015 12:56 PM
carolinabomb
Jul 26, 2015 08:40 AM
hondarider1234
Jul 21, 2015 11:53 PM
tporath
Jul 11, 2015 12:31 PM
D-Hagz
Jul 4, 2015 02:19 AM
