Plowing snow on 1/4 private driveway
Old Oct 29, 2010 | 03:36 AM
dilogdp's Avatar
Default Plowing snow on 1/4 private driveway
I recently purchased a home with a 1/4 mile private drive. Does anyone have any experiences plowing snow? I'm sure that my 09 Prairie 360 4x4 has enough power to plow but this seems like too long of a drive to do with an ATV.
I could buy a plow for my 3/4 Chevy but I'm sure that it would be very expensive.
I've heard that snow forms into ice and makes it very difficult to raise and lower the blade on an ATV.
I've never used a snow plow on a truck or an ATV, so I am unfamiliar with the process.
Old Oct 29, 2010 | 05:37 PM
Boss Man's Avatar
A 1/4 driveway is a long driveway for an ATV to handle, but it can be done. Depends on the driveway (flat, hilly, dirt, paved... etc). It also depends on the type and amount of snow you will attempt to plow. A few inches of dry, fluffy snow is not bad. Six inches of heavy wet snow on a driveway that size may be too much.
Good luck.
Old Nov 2, 2010 | 12:28 AM
bruteforce65006's Avatar
i plow my 1 mile long private drive with my 06 650 bruteforce. it does a great job if u go about 10-15 mph it throws the snow to the side dont matter about ground. unless u hit a snag and the blade folds down. my blade is home made. and its 1/4 inch steel angle and a blade. with snow guards on top. and i have it welded up so it dont fold down. our road is tar mixed with gravel. it does great and iv never had trouble raising and lowering it. i also have a 3000lb winch that does that job for me.it depends on if u can handle cold weather or u want to be in a heated cab.
Old Nov 2, 2010 | 01:49 AM
codyspratt's Avatar
Talking
my drive is probly 1/8 mile to the house then just a couple runs 2500 to 3500 ft to the back garage an the barn I plow it with my OLD reliable 2000 polaris 500 sportsman with a 48 in plow that i had another 2 feet added to it making it 6FT wide and it does fine if i hang 30lbs on the blade an ajust the skids i can get it to cut to the blacktop !!
Old Nov 17, 2010 | 10:02 AM
CReynolds's Avatar
I got a 1990 Kawi Bayou 300 4x4 with a 60 inch blade and it does well plowing any type of snow...i think you should be fine as long as you just keep the speed up they just throw it like a full size road snow plow.
dannytas
Sep 26, 2017 06:31 PM
shimanok2
Jan 29, 2016 07:37 PM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
