honda 200x confusion
Old Nov 2, 2010 | 05:14 PM
Digity17's Avatar
Default honda 200x confusion
ok i have 2 honda 200xs that i bought and i cant get either of them to idle. i made sure there werent any leaks in the intake asseblies. 1 is completly stock and the other has a full DG exhaust on it. Im pretty sure the carburators are stock. would i need a different jet? idk please help if you can. neither of them will idle!
Old Nov 2, 2010 | 11:04 PM
nickdodd25's Avatar
Turn in the screw on the right side of the carb by the silde on the side. The screw has a spring on it. Dont turn it too far or it will rev really high.
Old Nov 3, 2010 | 03:17 PM
Digity17's Avatar
ive tried that and the pilot screw towards the front and it still wont idle.....
Old Nov 3, 2010 | 04:09 PM
Digity17's Avatar
correction....they will idle high..but not at where they should idle...any help is appreciated
Old Nov 3, 2010 | 05:37 PM
mikel1's Avatar
On the pilot jet from the lightly seated position turn it out 2 1/2 turns then turn the idle screw to set the idle. If this doesn't work then try cleaning the carb if you haven't already.
sdm111's Avatar
2 strokes or 4
Have you cleaned the pilot jets and the oriface they screw into?
Old Nov 3, 2010 | 05:39 PM
sdm111's Avatar
2 strokes or 4
The pilot jet or the air fuel mix screw?
Old Nov 3, 2010 | 07:21 PM
Digity17's Avatar
ive already cleaned the carb. but il try the 2 and 1/2 turns on the piolet screw. i have 2 carb rebuild kits coming tommorw so i hopefully that works as well....
Old Nov 3, 2010 | 08:46 PM
posty2100's Avatar
http://72.52.143.80/~trikes/atc200x_...vicemanual.pdf
Old Nov 4, 2010 | 05:02 PM
Digity17's Avatar
Hmmm...ok so i cleaned and put the new parts in one of the carbs and it seems like something is sticking because when i move the wheeler around it will rev really high and stay there until i turn the idle screw down...also if i rev it it will stay at that rpm that i reved it to....still confused
