Pilot jets
Old Nov 10, 2010 | 12:43 PM
MECHANIKE's Avatar
Default Pilot jets
curious at 800ft above sea level if i should go from 30 to 32.5 on a 250/34mm carb and 40 to 42.5 on a 500/40mm carb or go from 30 to 35 on the 250 and 40 to 45 on the 500.looking for alittle stronger idle/off idle,,,,,,,,,,,thanx much people/its been a few months.also i know a place that will sell you up to 10 jets for only $1.88 delivery,,,,,,,,,,,
Old Nov 10, 2010 | 05:42 PM
4getful2's Avatar
i think the stock ones are good to 3000 ft. above
Old Nov 11, 2010 | 08:09 AM
sammydogs64's Avatar
I have worked on a ton of carbs in my life and with exception of my street bike (Royal Star 1300) I have never messed with pilots. All of my quads, Quadracer, Foreman, Prairie, Artic Cat 650 and now Sportsman 700, I have modified all of them and had to richen the mains but never touched pilots and never had a problem. Its not often that I cruise at 1/4 throttle, its either idle or 1/2 - full throttle all the time so Pilots don't make any difference.
Unless you like to (put put), pilots don't do much. You can always lower the needle clip one postion or install a .020 shim under it to get the 1/4 throttle change.
Old Nov 11, 2010 | 08:46 AM
MECHANIKE's Avatar
thanx people, now that its gettin colder it does'nt have the off idle smoothness,i'll give her a cleaning.
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
