Sticky shifter rod on 96 Xplorer
Old Nov 15, 2010 | 01:34 PM
xplorer400rookie's Avatar
Default Sticky shifter rod on 96 Xplorer
What causes the outside shift rod (one closest to leg) or linkage to stay stuck inside of shifter box and not allowing me to shift from forward to reverse, until I take a screwdriver and manually push it back?
Old Nov 15, 2010 | 05:08 PM
Kerbbirds's Avatar
try adjusting the linkage, put machine in nuetral, remove the nuts that connect the rods at both ends, adjust rods so that the ends line up perfectly with the holes at all 4 places, that should help, also there is supposed to be oil in the shifter. it may be dry or could have gotten water in it causing it to rust inside, it comes apart, if you have a service manual it explains it.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
