What's this? (400ex carb)
Old Nov 17, 2010 | 09:05 PM
rich1340's Avatar
Default What's this? (400ex carb)
I bought an 07 400ex (upgraded from my 01 300ex) and I'm getting ready to tear into my carb and I noticed this hose sticking out and not going anywhere. Is it just a vent? My first thought was a vacuum line for the petcock, but then I saw that it is not a vacuum operated petcock. I see on it's located in a place unusual for vacuum so I started it to see if it was. As expected, it's not vacuum. What does it go to? If it is just a vent, where does it lay? Thanks in advance!
Old Nov 18, 2010 | 04:21 AM
Williebee's Avatar
Post What's this? (400ex carb)
It look's like a vent hose/bowl/overflow the way it's routed up high , i could be wrong but that's what it look's like to me ; look's like 2 hose's hooked into the one you're holding!
Look for another hose hooked to the bottom of the carb bowl , if there isn't one on the bottom ; then it has to be for the carb vent/overflow .
Good luck to you and welcome to the forum !
williebee.....
Old Nov 18, 2010 | 12:48 PM
killer454's Avatar
if you lift up that rubber pad i think it has a hole in the frame tube right there it gos down in.
Old Jan 29, 2011 | 05:35 PM
dave6234's Avatar
it goes right on top through the black rubber peice with the other hose
Reactant
Mar 30, 2022 02:08 AM
GregM
Jul 29, 2015 09:41 PM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
