rebuild starter motor ?...
Old Nov 20, 2010 | 08:35 AM
nscrfrk's Avatar
Default rebuild starter motor ?...
...Is it possible and worth it?...Think the starter motor on '94 Kodiak is bad...direct connect to battery produces nothing. Rebuild or buy new? Parts fiche wants $230. Anywhere cheaper?...Thanks
Old Nov 20, 2010 | 09:20 AM
KQ400Pilot's Avatar
As long as the commutator is not scored (happens when the brushes are so worn that the brush holder grinds against the commutator), all you'll probably need is a set of new brushes and a bearing. I've done this on starters and alternators-pretty easy process.
Hitachi and ND make a lot of the starters for Japanese motor products. I would disassemble the starter, and take it to a automotive electrical shop. They can then order you the parts required. Set of brushes and a bearing will be a lot cheaper than a new or rebuilt starter.
Old Nov 20, 2010 | 10:24 AM
nscrfrk's Avatar
Ok...are you talking starter or starter motor? (that which engages the starter with battery cable attached is what I am refering to)...Thanks for response
Old Nov 20, 2010 | 01:08 PM
KQ400Pilot's Avatar
I use the term "starter" to mean the starter and its internals (motor).
Rebuild the starter if you can--much cheaper than a new one, plus, you'll have the satisfaction of doing the work yourself, and saving $$.
Old Nov 20, 2010 | 04:19 PM
nscrfrk's Avatar
Talking
This is getting funny...I am meaning the "starting motor". It is bolted to the outside of the "starter" itself. There is a geared shaft on the "starting motor" which engages the gear on the "starter". It performs the same way a solenoid (bendix) on a car works.
Battery>Starter Relay>Starting Motor> Starter
Old Nov 25, 2010 | 08:15 AM
Kerbbirds's Avatar
Look on ebay you will find them cheaper DB electrical is who I've dealt with
Old Nov 25, 2010 | 09:53 AM
TLC's Avatar
TLC
I brought my 89 Yamaha 250 Moto4 starter to a auto electric repair shop and he rebuilt the starter for $90 when a new one would of cost 3x that at my Canadian Yamaha dealer. It worked fine after they fix it.
ghost civic
Jan 15, 2020 07:43 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
