Superwinch question
Old Nov 22, 2010 | 11:23 PM
noooooo's Avatar
Default Superwinch question
I installed a 4500lb superwinch on my trailer. I accidentally plugged the handlebar switch wires into the contactor backwards. Will it hurt anyting to reverse the wires that bolt to the winch to make the switches work in the correct direction? It would be about 5 times as long to change the wires on the contactor because it is "buried". Thanks
Old Nov 23, 2010 | 12:52 AM
james feeney's Avatar
Shouldn't hurt at all. Assuming there is only two connections on the winch motor.
All the contactor does is deal with the high amps, and sends the juice down either wire for in or out.
JF
Old Nov 25, 2010 | 03:10 AM
chuck_raduenz's Avatar
there is no reason you would have an issue. the contractor it just like 2 relays reversing power to the winch for in and out. just that if your switch says "in" your going out.
Old Nov 25, 2010 | 08:31 PM
noooooo's Avatar
Thanks guys, I didn't think it would hurt anything but I wanted some reassurance before I did it.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
