4-wheel drive in reverse
Old Nov 27, 2010 | 08:29 AM
wayout's Avatar
Default 4-wheel drive in reverse
does anybody know how to make the 4-wheel drive work in reverse without buying that kit from quadavater,like cutting a wire or splicing a wire to another or something like that,i just want mine to work automatically when i put in reverse,just like it does in forward,i have a 2008 sportsman 400,any info would be appreciated.............
Old Nov 27, 2010 | 08:51 AM
Polarat's Avatar
I have heard of people using a zip tie on the over-ride button. Never tried it myself though. It would be handy when plowing.
Old Nov 28, 2010 | 09:25 AM
switzomatic's Avatar
If the wiring for the awd is the same as the 500-800's then here's an easy mod. Pull the top off the headlight pod and locate the big wire harness going to the speedo. There should be an orange/white wire. Pigtail a wire off that and another off the ground wire from your accessory plug(or any ground wire). Hook both pigtails to a toggle switch. With the switch ON you should have full power/awd in reverse. You will need to put the switch in the OFF position to use the yellow override button to scroll through the different speedo functions. Hope this helps!
Old Nov 29, 2010 | 09:56 AM
CO500EFI's Avatar
There is a way to do this with a relay so that you dont need another switch - just put it in reverse and go. I have found the instructinos on how to wire it on the older sportsmans, just not for my '08. I dont see what year your machine is.
Njrider1230
Jul 29, 2023 05:16 AM
Polaris5
Aug 29, 2015 09:11 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Schneider
Jul 24, 2015 05:05 PM
